need some vacuum routing help
There is a hose from the coolant reservoir back to the thermostat tower for vacuum return of the coolant as the engine cools. There is a second connection on the reservoir that is not open and is not used.
The only other vacuum line is from the part load breather orifice, on the forward of the left valve cover back to the throttle body.
What 'control valves' are you referring to?
I hope it was just a matter of semantics, but there are vacuum lines and coolant bleed and vent lines that look the same on an XJ8. Be sure you make no connection between them. You are talking about the small lines that connect to the colling system, right? They are not engine vacuum lines.
![Arrow](https://www.jaguarforums.com/forum/images/icons/icon2.gif)
Merry
XMAS,
I HAVE A PICTURE HERE ITS NOT THE BEST EXAMPLE BUT I was wondering if you can help me out by were this vacuum line goes to or even if it is a (v.line?)
I HAVE BEEN EXPERIENCING OBD II CODE P0174..AND I CAME ACROSS THIS CUT LINE...
THANK YOU JF AND HAPPY HOLIDAYS
![Icon Doh](https://www.jaguarforums.com/forum/images/smilies/icon_doh.gif)
![Icon Playing](https://www.jaguarforums.com/forum/images/smilies/icon_playing.gif)
Merry
XMAS,
THANK YOU JF AND HAPPY HOLIDAYS![Icon Playing](https://www.jaguarforums.com/forum/images/smilies/icon_playing.gif)
someguywithajag (12-16-2018)
