Need Wiring Harness
Hi all hope everyone is safe and well
I am trying to find the part number to replace the wiring harness that connects to the alternator, a complete one to where ever it comes from, as mine does not have the correct colors and has been joined
I have replaced the alternator and bench tests fine, but the warning charge lamp stays on.
Yes I have checked current and voltage at the battery when running and all is OK.
So after finding damaged wiring decided to replace that part from plug to plug of the wiring loom.
any help is greatly appreciated
regards Dutchy.
regards Dutchy.
I'm going to guess that the ENGINE WIRE HARNESS (COMPLETE) is NLA. (No Longer Available)
There is a large rectangular connector behind the throttle assy and THAT is where the engine harness begins.
It mates the car body to the engine electrics.
The alternator wire with the connector is PART of that harness so you will need the ENTIRE harness assy. if you want a complete 'connector-to-connector' harness.
The battery positive wire to the starter and alternator is the other connection and that is separate.
what I have found
LCC3320CC SNG Barratt says 1 found but then looking into it Unavailable
LCC3320AC SNG Barratt says 1 found but then looking into it Unavailable
AJ83882 NLA
AJ83881 NLA
So it looks to me second hand only
Tomorrow I will remove and inspect the existing harness further
AJ83882 NLA
AJ83881 NLA
