new 1998 xjr
So I finally got it today. it has a stumbling problem from time to time, I opened a thread o this but I will have it addressed next week.
Here is a video of the engine. I hear a slight rattle sound coming from a place that looks like timing chain to me. The engine is "new" the original engine was replaced with this one which has 60000mi and the transmission is rebuilt. The mechanic told me that the tensioner problem is addressed. Anyway what about this sound ? does it look weird ?
I never had a xjr before so I can't tell.
thanks a lot.
thanks a lot.
Received 1,797 Likes
Do you have an engine stethoscope to help you dial in the area of the noise? There's a couple things that could be making that noise, one being the tensioners, the other the SC coupler. Another cheaper easier possibility could be an idler pulley bearing.
xjfourty (08-15-2018)
That's probably tensioners, perhaps only the secondaries. You can remove the cam cover and view them. Look in my sig under the How To link and find a link by blackonyx which will be on replacing both primary and secondary tensioners, guides and chains. But the pics alone will help guide you to what you will view when removing the cam cover.
Highhorse (08-16-2018)
Dhighlife27
10-09-2016 08:07 PM
firstchoice
05-25-2016 08:30 AM
kamalislamof
12-22-2015 06:10 PM
BruceG
08-12-2013 02:41 PM
Ipc838
08-26-2012 01:27 PM
