New brake lines
New brake lines
I am planning to replace my brake lines shortly.
Can someone confirm that the OD I need to look for is 3/16? Also what thickness should I try to get?
What about flaring and compression? Will I need any new fittings for the joints or can it all be done with the pipe, a flarer, and a bender?
Yeh, use kunifer
Cupro Nickel Kunifer 3/16
Made a full set for my rebuild - I use it on all restorations, it's the best stuff by far.
A bench flair, along with a hand held for on the car helps. Take one off copy it and fit.
One at a time.
Hope that helps.
One at a time.
Hope that helps.
clubairth1
29
05-10-2024 12:57 PM
1964Daimler
09-09-2015 11:28 AM
