New caregiver for a 2003 XJ8
I decided to give a new introduction to my new reason for being here. My brother-by-law has had this XJ8 for about 4 years from what I can tell. He shared a few issues with it with me and is allowing me to help him with it.
I guess I'm going to be it's new caregiver for the time being. Pretty clean car, as most of them are. No one, let me back up, not to many people hand these cars down to the young. He purchased the car for his college bound son who opped out for a Grand Prix or something else. Didn't want an old man's car. LOL
I've had the car for about 4 days now and have a short list of issues that I'm going to be working on. In the process I guess I will learn some things, share some thing, and maybe even make a few video's.
Things done so far:
So far I think I have driven it about 100 miles. Starting to get use to the heavy feel.
Things done so far:
- Near dead battery. Had to jump it, charged up good.
- Oil change. Seems like it was 10,000 miles PAST DUE and off the stick.
- Brake light issue, brake light would not go out. Bypassed and piggy backed off the other side.
- Antenna broke off, replaced the mast.
- ABS light.
- Lights out in the climate control display.
- Broken head lights.
- Passenger door stuck closed.
- Roof liner falling.
- Remote does nothing.
- Cruise control may not work.
- May have an oil leak.
- Noise in front suspension, maybe end links.
- Third brake light loose from rear glass.
- Broken front bumper marker light lens.
- May be past due spark plug replacement.
After seeing your many posts about your "brother's issues" I was beginning to think you were a home mechanic looking for a quick repair of a customers newly inherited problems. I'm going to tell you what others will eventually say--"Search" is your friend.
My initial questions went unanswered when I first purchased my x308. Lots of searches and a few helpful members and she's slowly getting back to a respectable state.
As you're now inheriting a project good luck. There are quite a few how to's and videos on the forum. You might save yourself a little repair time by avoiding new videos unless you're going to improve and be more specific on the write ups currently in the sticky section.
I seen your previous oil change video and your challenge with the battery issue.. once again, good luck on your inherited project and welcome to the forum.
I seen that battery door issue. I'm going to try to pull the panel today and un-plug it, then plug it back in to see if that resets it. My issue seems to be different seeing how most do have doors that will not open, most say they don't lock or unlock with the system, this one is stuck closed and will not open at all.
I do search some and have seen a few solutions that I didn't ask about. It's kinda normal for members to ignore new posters due to the repetition. LOL I understand and don't knock 'em for that. Heck, it's hard for me to reply to some of them myself being a frequent member of a few other forums.
I have not seen a lot of videos but do add my own at times. I try to make sure mine are more visible and show tools required and sometimes more details. Not that I think mine are better, just some people need a little more details and guidance. Besides that, I have no control over when someone may remove their video's leaving a hole in the system. More is sometimes better.
Thanks for the welcome. I will likely see you around.
I guess this statement is partly true but the car does belong to my brother. Due to a terminal health issue with my wife, I had to quit my job to care for her full time. I do odd jobs to help keep the lights on, etc. I can only leave her a couple of hours per day. So I do a lot of different things to make a few bucks, within reason.
Once again keep you and your wife in my prayers.
Thanks, I appreciate the prayers. They helped me get through the really rough part, when the doctor gave her 4 to 6 weeks to live over 4 years ago. Phew!!! Tough adjustment.
I was able to pull the rear door panel off without removing the rear seat and the latch lock actuator has something inside of it causing it to get jammed. I was able to break it loose but every time it locked it jammed again. I can hear and feel the motor in it operating but the plunger keeps getting stuck. I unhooked the plunger till I can find a replacement. ******* has them as part of the latch assembly for $485+ so I'm going to look for a used replacement.
xjrjag
09-24-2015 10:08 PM
Ipc838
09-13-2015 03:27 PM
kabs3012
09-12-2015 10:40 AM
