New fuel filter installed and now P0455 code
Just got a new fuel filter installed yesterday and today I get check engine light with a P0455 code. Did they cause a leak when they installed the filter and now I should be worried or is this something that just popped up cause of the filter change and I can clear the code and be fine?
Jennifer S Flavell (02-04-2016)
disconnect the battery ground cable FROM THE BATTERY, and touch it to the live terminal for a few seconds
If those instructions are a bit too vague just search this forum for "hard reset" it's a well covered & highly coveted trick around these parts lol.
If that doesn't work & it comes back, return to whomever serviced it & have them check their work.
Also, clear the code with an OBD II reader. That should clear the OBD II and the check engine light. Then at the battery, in the trunk, disconnect the negative cable and touch it to the positive post ( as noted above, this drains all capacitors and resets the ECU to its baseline; the car will run rough for a minute as it relearns, but it will stabilize).
The following 3 users liked this post by plums:
philwarner
02-02-2016 10:54 AM
