New Jaguar owner & I need help!!
I am a new Jaguar owner, I've only owned my 2002VDP for 29 days and it has been great until 11/1/2015.
I just had P1384 & P1396 show up today. It lost some power then I heard a knocking sound, bummed!!! I checked the oil last week and it was full and clean, after the nois and codes the stick was dry!? No oil leaks on my driveway and no oil on bottom of car.
What should I do?????
Any advice would be greatly appreciated!
Last edited by JZjaguar; 11-02-2015 at 01:14 PM. Reason: Added info about oil level
Yeah- that does not sound good and I would have a hard time believing that trying thicker oil is a good idea. As I assume you know, the codes are for both VVTs and are not specific to the electrical circuit, so I ASSUME that it means the feedback does not match the command. I would say there might be a tensioner failure except it is both sides.
I would sure like to know the oil pressure was good before I ran that engine at all since the symptoms both match no oil pressure.
JZjaguar (11-02-2015)
Over on the Xk8 forum there is a recent post
VVT solonoid noise and P1384 chk eng lite
Take a look. You would have to be three qts low to have dry dip stick. You might try adding oil . . . But be mindful of the risks Ross pointed out.
If you have some experience, adding oil to test the pressure might be illuminating, if not get it towed to a local Jag specialist. If adding oil quiets the noise, look for blue smoke out the tailpipes and double check for drips, the oil went somewhere.
Well I had the mechanic who has taken care of this Jag for the last 50K miles come by to check it out. As soon as he started the car he shook his head, NOT GOOD! Said it is something in the bottom end but is baffled because there are no leaks and no smoke out of the exhaust.
Anyone have an guestimate on the price of a rebuild or buying a used engine? Its a V8, 2002 Vanden Plas edition.
Thanks in advance
Thanks in advance
JZjaguar (11-07-2015)
Thanks LowellLamb but no lights came on until after the knocking and it was the engine light. Looks like something catostrophic has happened. My mechanic is looking for a used engine for a replacement but that scare me too, not knowing what I'm getting myself into with a used engine. I'm very bummed, I only had it for one month!
I agree with the Addict. Many of the engine parts are not readily available so you might be waiting for a while unless it is an exchange. Most used engines bought from relaible sources come with the history of the donor car.
BTW, and i know you don't want to hear this now, but your experience is why these cars can be a bad deal for someone who does not want to do some major repair work themselves. I do admire your lack of whining for your bad luck.
I had a 1999 Vdp and as I understood it, the cam chain tensioners were problematic from 96-2002.After that they changed them as the plastic cracked. Car will be noisy,run rough possibly, and you might find plastic or metal fragments in the oil. Mine died at 116k. Had to have the cam chain and tensioners replaced. It will probably run 4k and you will need a special installation tool kit also. If you are mechanicallying inclined this site has good instructions on how to do it . The tool kit and cam chain tensioners will only be about $1000. I had to buy the kit and had a competent mechanic ( non jag specific ) do the job for about 2k. Might for the purpose of getting your heart racing go to a jag dealer and get their estimate before your consider an engine swap?
I would still look for a low mileage used engine. There's got to be a lot of damage in there. The camshafts are the last to receive oil. There's just so much machine work that needs to be done to repair that engine. Besides, a used engine will get you back on the road much faster.
Let me suggest a different option you might want to look at: for $6000 you can probably find a nearly perfect XJ8 or XJR in the Southern California area. Then, trade off the best parts from the older car to the new one and sell the hulk as a parts car.
Last edited by Jhartz; 11-14-2015 at 01:12 PM. Reason: "Siwi, for kwist sake, what's wong with you."
JZjaguar (11-25-2015)
