New JTIS21 CD download with download instructions
#81
Hi Chris
The Engine Cooling System information - Use XJ Range as Model and 1998 as Model Year, then click text navigator icon on bottom menu ( to open the list of procedures)
then click on 3: Powertrain,
then click on 303A: Engine Cooling,
then click on Description and Operation,
then click on Engine Cooling -- it brings up the Engine Cooling Components Diagram and components listing for NA and Supercharged Vehicles, also describes functions in more details.
If you cannot find a procedure in your model year (2001) then you need to look first at 1999 model year selection, if also not there, then look at 1998 model year selection.
A lot of times the procedure is not in the model year selection that you would normally find it, JTIS sometimes does not repeat the same procedures unless the procedure changes in a particular model year.
I copied the following information from the PDF on installing DAO350.dll (page 14):
Here are some tips on how to find vehicle repairs information:
Engine Cooling information is in the Engine Cooling section 303-03A for the Range Model XJ. It is only in the Model Year 1998 (and
not in 1999-2003 Model Year Selections).
Looks like the JTIS does not repeat a section unless something changes in that section.
Also in Range Model XJ Years 2000-2003 in Engine section 303-01 In Vehicle Repair subsection, there is only 1 repair listed - oil pressure switch.
In the XJ model section for the 1998 year, the In Vehicle Repair subsection (Engine Section 303-01)
has a long list of repairs listed alpabetically from Connecting Rod Bearing through Variable Camshaft Bearings Oil Control Unit Housing.
The XJ model section for the 1999 year, the In Vehicle Repair subsection (Engine Section 303-01) also has a long list of repairs
listed alpabetically from Connecting Rod Bearing through Valve Cover RH. Something must have changed between 1998 and 1999
So Range Model XJ for Range Years 1999-2003 does not have section 303-03A (Engine Cooling). You have to use 1998 model selection for your
You should also download and read this other PDF file - Instructions and illustrations on how to navigate JTIS21 software (set your pdf reader to the 125% zoom level).
Here is the weblink:
https://www.dropbox.com/s/xymg7uwowh...ustrations.pdf
Jim Lombardi
Jim Lombardi
Badbenz94 (01-23-2014)
#83
#85
#87
My first thought would be use a virtual machine to run an older OS on top of your W10 box. There's a few out there to chose from, Microsoft do their own & I know VMWare workstation is free as two examples. Have a google & the guides are pretty foolproof.
I did similar years ago to use Saab software which needed XP on a W7 laptop & it worked fine.
#88
#89
#90
Will the JTIS work on windows 11?
Hello,
I just found out about the JTIS and am very excited....but these are all old and I am wondering if they will work on windows 11 or not.
Thank you for time!
MainJag
Thank you for time!
MainJag
New JTIS21 CD Self extracting Archive files on my Mediafire account.
Here is the information you need to download the files:
1st download the instructions PDF file (Mediafire download & Extract instructions for JTIS 21.pdf).
Read the instructions PDF file (Mediafire download & Extract instructions for JTIS 21).
Then download the 3 archive files.
Run the JTIS 21 CD.part1.exe (this is self extracting file that extracts all the files in the 3 archives).
This JTIS 21 CD covers XJ model years 1995 thru and including 2004, XK model years 1997 thru and including 2004, S type model years 1999.25 thru and including 2004, and X type model years 2001.50 thru and including 2004.25
Also there is a separate Technical Guides -- This is an optional download (JTIS 21 CD Technical Guides.exe). It is also a self extracting Archive. It has 15 PDF files in it. Also cover AJV8, 5HP24, updates for XJS, XJ, XK, X300, etc. It is about 109 megs after extraction.
If you extract the files onto your C drive, then you run the setup.exe from your C:\JTIS21 folder.
You will be now using the JTIS21 database files in the C:\JTIS21 folder and you will no longer need to put the CD into your CD drive.
Also the C:\jaguar\jjtis.exe is updated after running setup.exe to use the database files in C:\JTIS21 folder.
IF you already have the DAO350.dll registered and working. You did not have to run the Disk1/DAO350/setup.exe.
Here is the link to the downloads:
http://www.mediafire.com/?54tdwq3vx0xub Update - mediafire.com problems downloads of large split archive files - they request a download fee.
Use the following dropbox.com download links for JTIS21 all models archive files:
Part1.exe is 190 mb (195313 kb)
https://www.dropbox.com/s/fvdg6rsl63...CD.part1.exe?m
Part2.rar is 190 mb (195313 kb)
https://www.dropbox.com/s/bwx4uch8m9...CD.part2.rar?m
Part3.rar is 58.9 mb (60318 kb)
https://www.dropbox.com/s/xk49mq38ch...CD.part3.rar?m
Please PM or post in this thread, anything that you feels needs improvement and any other advice you can give on the instructions, etc.
Thank you for your interest in my JTIS 21 project.
Jim Lombardi
Jim Lombardi
jimlombardi
07-02-2011 06:45 PM
jimlombardi
04-13-2011 05:44 AM
