New member xj8 flooding problem
Old 11-03-2010, 07:33 PM
ShaneIam's Avatar
Don't shut it off until it's hot. I've had this happen once and it was because I drove only 20' from the driveway into the garage. And I was able to get it started by cranking the ignition and rapidly pumping the gas pedal...
Old 11-04-2010, 11:06 AM
Jaguar kid's Avatar
I had the same thing happen to me, I was claying the car in the garage and had to move it 3ft the engine was on about 20 seconds, after I had finished my nice work on the car, wanted to move it out the garage, and of course it would not start, flooded, so I held the accelerator to the floor and turned it over till it started about 30 seconds and it fired up, I quickly leaned that these engine don't like being switched on and off to quickly, especially when cold.
Old 10-17-2014, 11:37 AM
Ccharlie1's Avatar
I had a (somewhat) similar problem with my "06 XK-8, and the shop is STILL trying to find the reason and the cure!
Old 10-19-2014, 10:28 AM
Jhartz's Avatar
But the correct approach to overcoming a flooded 308 is to hold the pedal all the way to the stop and crank it until it cleans out and starts. Don't crank it for more than a few seconds each time, the starter will heat up if you crank too long.
But maybe a can of SEAFOAM and a cleaning of the bore and throttle might preclude a problem in the future. How old are the plugs?
Old 10-20-2014, 04:33 AM
Ccharlie1's Avatar
Tried all of the above. Now they think it's the fuel pressure regulator.
Old 10-21-2014, 02:33 PM
Ccharlie1's Avatar
NEW fuel pressure reg seems to have fixed the flooding (couldn't FIX the reg?), but now there's a strange ticking sound (from engine)?
Old 08-06-2017, 06:52 PM
holybananas's Avatar
Do you know where the regulator is?
Chet Ramnarain (bozzner)
09-03-2015 07:47 PM
obwoodie
09-03-2015 07:45 PM
arnoldmilk
09-03-2015 07:42 PM
KarimPA
09-03-2015 07:32 PM
laserguy
09-03-2015 02:02 PM
Quick Reply: New member xj8 flooding problem
