New noise
The following 2 users liked this post by ericjansen:
Don B (11-15-2018),
King Charles (11-15-2018)
#82
Such the paradox as the car is what had my rear end moaning lol, a literal pain in my a$$ lol.
Edit :
With the bearings,correct rear diff. oil,me removing the failing plastic defrost vent/grills & the new addition of the Pilot Sport A/S 3+, this car is finally as quiet as it should be inside the cabin lol.
Edit :
#83
Update :
I'm halfway to my goal of 1,000 miles w/ no noise, now w/ the vacuum of silence, I hear my rear springs creak on bounces. The tech that serviced the rear said he dressed it in lube & anti-seize corrosion formula. But 18 years on a car that's seen the borderline tropical meets temperate climate of the south here, it's fair to say the springs did their duty. Hindsight is 20/20 & I should have replaced them when I had all the shocks & rubbers done. I haven't been able to find any new OEM or aftermarket springs, except those which lower. If I go the used spring route I run the risk of encountering more creaks, so I may bite the bullet & lower it.
My creak ended up being the taper roller bearing #15 driver side rear.
![](https://cimg3.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/740x958/x308rearhub_a9a794966b13c7d7ff0954c712d4385255c5fd1e.png)
skinnypuppy_22
01-12-2017 10:03 AM
