new owner help.
new owner help.
I bought a beauitful 99 xj8l. This car runs like a dream. But i did my research on these cars when I bought it. I poped a vavle cover off today and seent the red plastic tensioner no cracks that i can see. Car had no knocking sounds. So im gonna replace those anyway. So if any one can point me in the right directions as far as parts and any tools i may need. THe car has 116,000 miles on it. I have a question should i change the tranny fuild or not if so can someone point me to the parts i would need for that thank you veary much.
Sticky is your friend (click here)
Tensioners are $70~$80 a piece. Supposedly Lincoln LS (V8) uses the same tensioners and they run ~$30 each. Do some digging for exact part #. You may wanna rent the cam shaft locking tool ($75~125) Also, I'd suggest aluminum termostat housing (~$75) and metal propeller water pump (~$120). Motorcarsltd.com is where I was getting my parts while living in Houston...
Congrats and welcome
You can check in our vendors
JPAM
NALLEY
ebay
this also a reliable source
www.jagbits.com
Happy safe driving
JPAM
NALLEY
ebay
www.jagbits.com
Happy safe driving
Tensioners
Yes it's a very good idea to replace the tensioners now. The longer you wait the more you will need to spend. I did check the prices at a Ford dealer and the part numbers and prices I was quoted are:
RH Secondary tensioner - W0133-1655533 (Jaguar part #), 2W9Z-6K254-BA (Ford part #) was $78.82
LH Secondary tensioner - W0133-1655532 (Jaguar part #), 2W9Z-6K254-CA (Ford part #) was $87.98
You will also need 4 new shorter screws for the new tensioners.
Screw 4 each - W0133-1841258 (Jaguar part #), 2W500301-S300 (Ford part #) was $2.00 each
All prices above are the Ford dealers prices I was quoted. I ended up ordering from autopartswarehouse.com
Don't forget new gaskets for your cam cover. I can provide those later if you need.
