New Shocks?
Sorry for all the posts and problems. My 2000 XJ8 seems to be problematic, but actually the stuff that has had to be done to it is really just stuff that wears out. Anyhow, when I run over certain bumps and what not you can hear a thump, thump from the wheel. With the hood open you can see the top of the shock. It looks like the orange rubber there has deteriorated. Does that mean I need new shocks or is that rubber piece something else?
Blaze
Blaze
My 95 XJ6 did the exact same thing. I had new front shocks installed at the dealer and when I got it back it did the same thing. I found out later that they never replaced the bushings. I went to an auto parts store and bought shock bushings for about 7.00 total and installed them myself. No more problems. I would try this first as it is a cheap fix. If your shock bushings are just the standard rubber doughnuts. I never saw bushings just rot away like the jag bushings before! I would get something that's not hard though as I was told that hard bushings can damage the shocks but either way the problem will go away if it's the bushings. I'm sure that a local can install them for you if need be for a reasonable price.
shocks are likely not problem. Thats why I suggested the upper bushings - visibly deteriorated. The front stabilizer bushings and the bar end links are very easy. The lowers on the XJ I do not recommend doing on your own. If the spring comes out it can kill you. Leave that and shocks to the dealer.
It is the upper shock mount bushing. When I was doing brakes I noticed the crinkly, accordian looking thing that goes over the shock isnt even stuck at the top now. The rubber has seperated and it has fell down. This has started crapping out in just 600 miles. I guess once they start it doesnt take long.
I seen where a Jaguar dealer is selling a kit where you can replace the rubber pieces and not the whole assembly.
Blaze
Blaze
Chuck Schexnayder
33
10-24-2015 10:20 PM
dmatthewman
09-30-2015 10:10 AM
