New tensioners/start up noise
I installed new tensioners and before I did the engine had no noise, but the tensioners that I removed were in very bad shape. Engine runs very good but when I first start up after sitting over night there is a clicking noise that was not there before. Did I do something wrong or will it just go away and why did it not do it before.
Bill
1998 XJ8 VDP
Bill
1998 XJ8 VDP
Did you use new, (shorter) bolts to secure the new tensioners, as the bolts for the plastic ones are longer, and will bottom on the tapped holes before they secure the metal tensioners properly ? Having said that, I understand the new metal tensioners come with the new bolts; but did they ?
At rest there is a little slack in the chains as you note due to the valve spring pressure on the cam lobes trying to turn the cam a couple degrees. Are the cam flats almost aligned? If so the tensioners are probably OK.
Could the clicking be the VVT units? That is a common issue with older/higher mileage engines addressed by raising the oil weight a little.
How many miles on the engine?
Instead of changing the oil I drained a quart out and added 1 Qt. of Lucas treatment that ups the oil pressure. WoW! no noise and after I entered the post about never hearing the noise before, I got to thinking that I never goosed the throttle before the tensioner change.
now that is really stupid. I guess you were right about the oil pressure and the vvt units.THANKS much.
Bill
1998 XJ8 VDP
Bill
1998 XJ8 VDP
baskervillema
10-01-2015 06:43 PM
UKnFor-dluv-expat
09-26-2015 08:40 PM
