New used crank in original block.bearing questions
yea ill probably end up getting the used crank and have it polished. I have a feeling my old cranks rod bearings were melted to the journals
Dang Jrp79, I didn't know you were that close. I juat left Napa an hour ago after taking the wife wine tasting for the day.
I'm concerned that you lost 3 sets of rod bearings. What I understand that loosing a rod is not that common on our engines. Even if you lost 1 set that might be possible, but to loose three at the same time I think something else is going on. Was the engine to your knowledge ever syarvef of oil? Does the crank or rods look like they got hot? What do the pistons and cylinder walls look like?
If this engine was oil starved it could have caused significant damage to the rest lf the engine making it not worth while to repair.
I'm in Sacramento. Are you viewing this site in mobile or full site. On my post it shows where I'm from. It will show up on full site.
I might also suggest you put where you are from and in your signature state the year and model of your car. In my signature it shows my Jaguars and that I have 3 donor cars that I'm parting out.
It sounds like your engine might be OK, but I don't know about tbe crank. Having a rod banging on it without a bearing doesn't sound good to where it might only need polishing. But have it checked out to see what it will take to bring it to specs.
If you don't have a machine shop nearby I have one I used a couple of times here in Sac. I was happy with their work. We also have several members in the bay area that might know of good machine shops.
#28
Sorry about the misunderstanding of your location. When you mentioned napa I thought it was the town of napa, not the parts store.![Confused](https://www.jaguarforums.com/forum/images/smilies/confused.gif)
I did a quick searh and what I found is that the rods are the same until 02. All the rods are the same but they are installed in one direction.
The part # I found is NCA1610BAE.
Refresh me. What is the model and year of your car.
#30
Cars a 98 xjr
#31
#32
You need the code from the new crank. You will also need the codes on the new rods. You can't order them until you have this information.
Look at the flex plate end of your bad crank. There should be a set of 5 letters and a set of 4 letters. This is the code you need from your new crank. There should be a letter on each rod. Then you will need the code from your block. It should be 8 numbers and then a set of 5 letters.
Get this info then I'll help you figure out the sizes.
Was the crank your getting have any machine work done. If it has been reground the code is no longer of any use. Each journal will have to be measured.
#33
#35
#39
