New used crank in original block.bearing questions
#41
He only gave me the block codes...when I get it ill mic all the journals so I can get the proper bearings
#46
I was ill informed. The crank code is on the block. When I replaced the piston and rod bearing on my 2000 xk8 I was told that the code for the crank was on the end of the flex plate. Since I was not going to remove the transmission just to get the code I measured the bore and journal. I don't rember if I read it somewhere or was told by someone.
So with the codes you showed me you can figure out what bearings you need. Use your block code and the crank code from the block that the crank came from.
Again my apologies.
Again my apologies.
