new xjr!!
Hey everybody new to the forum and also new to jaguar ownership !! Im having difficulties finding an owners manual for it so I was hoping you gents could help me out on a few things ?
First off what oil and coolant I be running . My heat seems to be little to none and in canada that doesnt sound extremely pleasurable for the months ahead it's blow air just not very hot the PO installed some sort of switch for it but dont know its functioning ? And lastly a wheel bearing is bad and brakes are kinda shabby . I try to diy most thinga on a vehicle if possible so are the wheel bearing something ill be able to press my self back in and where do you guys recommend online getting brakes ?? Thanks for any help or extra info you can give I really just want to know this thing inside and out sooner then later
Hi
The forum is full of informations.
You must read a lot to understand all the things that you must do to your car to keep her in good shape.
Oil 5w30 Castrol for cold region. I use 5w40 but i leave near to the sea in Romania. I put inside BMW oil because is Castrol. Jaguar recomand castrol oil for X308 V8 engine.
Coolant Type G12 red.
Good luck
Good luck
