New Year, new noise ?!
Noise surfaces after intensive turning IE u-turns etc. sounds like a spring contracting &/or reeling ?! I've researched the forum & found it could be either the air bag seat springs or the clock spring. Hopefully it's the air bag springs as I'm replacing the wheel in the coming days. Anyways here it is, anyone have a definite answer as to if it's the clock spring I'd like to go ahead & order it & have it done when I replace the wheel.
The following 2 users liked this post by RJ237:
motorcarman (01-06-2019),
nilanium (01-07-2019)
Is it the squealing/whining noise you're talking about, or the creaking?
Mine started creaking/clicking several months ago when turning sometimes, the interface between parts of the plastic cover that goes around the steering wheel center is causing it. Maybe cleaning it with some dry lube would solve the problem, or some of that automotive felt trim tape, haven't had a chance to try yet. I can replicate mine by flexing the steering wheel (as if checking for bearing play) or squeezing the plastic bits by hand.
Try a light spray of WD40 or equivalent between the steering wheel and post, us the spray straw (do a search on removing the steering wheel, clock spring, or multifunction switch to see pictures of where the clock spring sits vis a vis the steering wheel). Light spray will quiet it down. Had to do it twice in the three years I owned the XJ8L. Worked both times.
King Charles (01-09-2019)
Ok new noise the 2020 version lol. It's a knock borderline rattle from the rear, Initially thought it was my 3rd brake light but that's secured. Shocks,stops,donuts,wheel bearings all done within the last 7K miles. My phone doesn't have the greatest mic but it resonates on a short drive w/ 2 turns on flat surface in the vid below.
Check the rubber exhaust supports on the top side of the rear suspension. It’s the ones where the upside down U shaped bracket hold the rubber down. Also check the rear mufflers and chrome tips to see if they are on tight. The rear mufflers you can bang on the underside with your fist to see if you can replicate it.
King Charles (10-16-2020)
Received 1,797 Likes
King Charles (10-22-2020)
Highhorse (10-22-2020)
