Newbie looking for some help with window switch
Guest
Posts: n/a
Hey all. Great forum here!
I'm having some trouble with driver side window on a 1999 xj8.
Symptoms:
- When the window is fully closed it no longer returns down.
- Window operates fine (up and down) so long as it never reaches the fully closed position.
- Disconnecting the negative terminal for 5 seconds and reconnecting it allows the window to break free from the fully closed position. But I can't close it all the way.
Cheers!!!!!!
John
Symptoms:
Cheers!!!!!!
John
Jonpiero, Another member may have better advice, but I had a similar problem, where my window would go down, but not up. I had to purchase a new switch cluster. I could only get the window up by bypassing the switch. The switch is fairly easy to replace, once you lift off the door panel. If you try a new switch, try to get your part supplier to allow a return, should it turn out to be something else. (the worst they can say is... no)
PS... I think I read in my manual that the negative terminal should be removed for a minimum of 30 seconds, to protect the electronics, I assume. Leave it disconnected a bit longer to be safe.
rentzoo
11-10-2015 04:56 PM
RaceDiagnostics
09-13-2015 02:22 AM
jagent
09-12-2015 09:10 AM
1964Daimler
09-09-2015 11:28 AM
