No cabin heat.... cold days approaching !
Going down my "to do" list on the '01 XJ8. While still keeping an eye on my bank 2 knock sensor giving me intermittent "restricted performance", my next agenda item is getting some heat in the cabin. Heater has not worked since I bought the car early spring - but here in NC the A/C working was way more important ! As we get closer to mornings flirting with below 40 deg, time to look into it. Yesterday, I replaced the auxiliary heater pump (just because I read it was the nr.1 cause of the malfunction). Unfortunately, this was not my problem (and found out my pump was working just fine - testing after the fact, stupid me). Next, I am thinking I am to replace the heater valve. So I'm throwing this thread out here just in case someone has experienced something similar but the problem was not related to the standard problems already found on the forum.
Stay tuned with more Blue_XJ8's agenda of stuff to fix. Next is the driver door no longer locking.
Thanks all for replies, and sorry for late follow up. So the latest on my end is that I am getting warm air, at most, after 20min drive or so with heater on "HI". Additional note is that the warm air comes out of driver side vents, not passenger side ! Not too sure if this is any kind of indication, but would think more towards the core than the valve. Probably not bad to clean/replace the valve, but sounds like I might need to clean / flush the core?
The heater core is like a radiator, it just have fins and tubes, the coolant heats of the core and the blower blowes the air. If the core was bad it would just leak, see if the carpets are wet/damp. If not the core is good.
Since you have air flow the blower motor is good.
I still leaning towards the thermostat, stuck open. If you getting warm air flow from one side and not the other, the vents could be stuck, that can happen if the vents was ever removed and not reinstalled correctly.
The heater valve is a open and close part, like a light switch either on or off. But, since you say it warm air, it is flowing. Maybe it half way open. Still leaning towards the thermostat.
How likely is the plastic radiator drain plug to snap off in my hand. It looks pretty frail.
Eric
Ok so I got my old thermostat out and I tested it. It won't open in boiling water.
The new one opens at about 185 like it is supposed to so I put it in, filled up and heated up the engine cycled the heater and still no heat.
My auxiliary pump and my valve both work. The coolant is clean and the correct orange jag coolant. I suppose the core could be clogged but I doubt it.
Is there some other thing I should be looking for? Is there a cold/hot air vent or door that might be stuck?
Eric
Eric
