NO Compression.
You do realize that the car in the video is a Mazda, correct? It's not his Jag.. He's just using it as a sound reference.
These all mean the same thing, starter spins, but the engine will not "run" or try to start.
The engine to turned over, but it wouldn't fire up.
The engine cranked, but wouldn't start.
It would spin, but wouldn't catch.
And fire doesn't mean run well either.
"Engine would fire, but it wouldn't run." Means it tries to start then dies.
I don't know why "crank" has come to mean "start or run" lately, but it is a commonly confused term.
Gotta be careful though, I got jacked for insisting that our "cam covers" be called such and not incorrectly called "valve covers."
Will she crank, will she spin, will she fire, will she run?
If it will crank but not start - bore wash, fuel pump or inertia switch.
If it will not crank - Battery, starter, grounds, security system fault + 100.
Vector
The definition of turning over.
It means that the battery has enough "juice" to turn the starter motor, which is "turning the engine over"...but it won't start and run on it's own.
The following 2 users liked this post by blackhonor9:
Johnny_B (08-21-2016),
motorcarman (08-21-2016)
Dennis Catone
04-28-2016 10:16 PM
hankycbr
10-28-2009 01:42 PM
