No Crank, no start.
No Crank, no start.
Howdy from Illinois!
I have a 2003 XJ8. It started out very intermittantly not cranking. Turn the key and the dash lights up as usually, but no crank. Yesterday, it appears to have permanently adopted this habit, which should make it easier to find. I was thinking starter and going to check starter for powers & grounds. However, when the key is turned on and dash lights up as normal, I put my foot on brake pedal and expected to be able to put car in neutral. It will not come out of park. The car is locked to the earth. Tried different a key (car came with 5, 3 regular/2 valet) and there is no change.
I'm half expecting an ignition switch issue because I can't get it out of park like most cars, although Jaguars aren't most cars. I still plan on checking the starter and it's connections, just in case.
I searched forum for no crank and found nothing. Has anyone encountered this before?
Thanks for your time.
While you're waiting for an answer, you could go to the New Member Area - Intro a MUST section and tell us something about you and your car.
Again with this No Crank problem.
Good afternoon! I made the original post over 4 years ago. I never have found a solution. Fast forward to Christmas Day 2016, gifts loaded up, wife and I ready to motor..........Dash lights up, nothing from starter. No click, no nothing. It does this very, very sporadically. Might not see it for several months at a time. Usually cranks on the 2nd or third attempt. Not this time. It never does it for long, when I come back for diagnostics, it starts fin, just like it did today. When this occurred, I depressed the brake pedal to put the car in neutral to see if it would crank that way indicating a neutral safety issue. The car would not come out of park.
As I said, it is now working fine. I'm leaning toward an ignition switch issue or possible connections on the steering column. I haven't stripped the column covers off yet to check. Has anyone out there seen this and solved it? Thought I'd ask again before I dive in headlong. I searched but didn't see anything jumping out at me.
Thanks in advance for any help you can offer.
Did you ever check the power stud on the false bulkhead connector as was recommended???
I find this fault a few times a year. It usually is melted so it is a 'dead-giveaway' that the connection is faulty.
Also check the 'HIGH POWER PROTECTION MODULE' (AKA Megafuse) in the boot in front of the battery and spare wheel for corrosion/connection.
bob
bob
bob
bob
Thanks for the reply! It is very much appreciated.
Yes, steering column and seat come to life with key, it's just no start and the shifter will not unlock. This past weekend I replaced the ignition switch because of this problem. The feel of the ignition tumbler is different now, I do not have to turn the key as far as I did before to engage the starter, now it works like a new car whereas before I had to turn the key all the way until it stopped. I believe my issue was that the ignition switch was worn out and simply could no longer make contact. It is a fairly easy replacement. I also replaced the multifunction switch (turn signal/wiper/headlight/trip computer/etc.) because the speaker failed and no longer sound for turn signals or key in ignition. As the steering wheel was rather worn and the airbag was scratched by previous owner, I replaced those as well. Now everything is working and the steering wheel leather and airbag appear as new. Happy wife, happy life!!!
The following 3 users liked this post by 007:
WTB[MidWest]: Jaguar related banners, pictures ect.
noterman
11-07-2015 06:18 AM
gunlocators
09-30-2015 08:05 AM
