No Kick down on XJ8
Guest
Posts: n/a
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
I have XJ8 1998 model - the problem is when i hit the pedal at 50mph the car will not kick down a gear or accelerate as it used to - if use the gear stick and go down the gears the car kicks down and acclerates as it should. Can anyone help and explain what may be the problem? Is there a electronic switch or something similar that may need replacing ?
Rish's question was from 2009, six years ago! I think he either found the kickdown switch under the accelerator pedal or moved on to something else by now.
Alden
