No rear door courtesy lights
I’ve heard that if you spray enough WD40 into the door latch that it’ll work it’s way into the micro switch to free it up. With the rear doors open, sit on a stool and with one hand (or a helper) keep the inside door handle in the open position while using a screwdriver to move the lock back and forth a bunch of times. The only other thing I know of is to replace the lock/latch assembly.
3timejag (01-19-2022)
