No starter turnover, Battery good.
ocphippsjr (05-12-2014)
Have a look at the "false bulkhead" power connectors on the outside of the boxes at each side of the firewall. Then check the power connections on the fuse panels. Check the inertia shutoff switch. With some more info concerning the condition of lights and dash indicators someone can help you narrow the search for the cause.
FWIW, "dropping the starter" is a royal PITA on these cars, so a lot of diagnostics should happen before embarking on that adventure!
The following 2 users liked this post by sparkenzap:
Don B (05-06-2014),
