No tail lights
Old 09-30-2020 | 10:56 AM
aquifer's Avatar
Originally Posted by Jackson_Dkmg
Fun times.
Until I could take a decision regarding the replacement of the BPM and the version to use, I decided to wire the output of trunk fuse #21 directly to the tail lights -- I'd have the dashboard error, but at least, lights.
Removing the tail lights assembly, I banged the left one a bit too hard, and noticed the second filament of the brake/tail bulb had broken down. Dammit. So I went to buy a spare.
Mounted it : EVERY. THING. IS. WORKING. PROPERLY. Tail lights are back on, as well as the front side markers.
I don't understand. I'm guessing the original bulb was misbehaving even though both filaments looked fine, but I can't see how it would wreck such havoc. It's not like the tail lights and side markers are mounted in series? I think.
The battery, unfortunately, seems to be on its last legs... currently in charge, it didn't have enough power to start the engine.
Not to add insult to injury, especially since I'm the insulted one, but I strongly suspect that the battery was fine until I did a short circuit a couple days ago and put the car in lockdown/antitheft protection.
All this to say: sorry for having wasted your time with a nonexistent problem
Don't try to make sense of it, just roll with it! When you have a problem, the secret is to just stay with it and eventually you figure it out, or you stumble onto a fix. You didn't waste anyone's time. In fact, this thread may be very useful to someone else who has the same problem sometime.
Old 09-30-2020 | 12:06 PM
Jackson_Dkmg's Avatar
Hopefully so
Also, the battery seems to be holding up so far, I hope it stays that way!
Old 11-20-2021 | 04:11 PM
Kringe's Avatar
just fixed to same issue in my 02 VDP but in my case the tail light bus was shorted to ground on the rear light holders
Old 11-20-2021 | 04:50 PM
Parker 7's Avatar
Old 11-21-2021 | 03:01 PM
Reddevil's Avatar
Originally Posted by Parker 7
Thanks. I saw that. It might as well be in Mandarin. Cant read those.
Old 11-21-2021 | 03:56 PM
Reddevil's Avatar
so, I should use a test light on "R" and "U" with the ignition on?
Old 11-21-2021 | 04:44 PM
Parker 7's Avatar
Reddevil ,
The terms fog and running may be mixed up on the print , different English languishes
But yes on power at the red and blue which should be the center pins on the bulb sockets
There is a history of the socket ground path lacking which would allow enough current to pass and illuminate the bulb but not enough to not trigger the current sensor to give you the light inop indication
incorrect bulbs will do this
Reddevil (11-21-2021)
  #28
Old 11-21-2021 | 04:48 PM
Reddevil's Avatar
Reddevil ,
ok, test bulb socket first. I thought he wanted me to test the module.
Old 11-23-2021 | 09:12 AM
Reddevil's Avatar
Using a test light, power on, I have power to green wire on left rear (US passenger) and power on red wire right rear (US driver). Nothing happens at the brake light bulb wire. It is orange on drivers side, and orange on passenger side.
Parker 7 (11-23-2021)
  #30
Old 11-23-2021 | 09:56 AM
Reddevil's Avatar
I dont see any broken wires by the hinges down to the bulbs.
  #31
Old 11-23-2021 | 10:04 AM
Parker 7's Avatar
Not quite sure of the wire colors you mentioned but we can go further
Do you have the 3rd brake lights or high mounted upper center lights during brake pedal depression
Fuse check
Relay swap
This is a pic for a fuel pump issue but your relays are in the pic
  #32
Old 11-23-2021 | 10:22 AM
Parker 7's Avatar
The 2 oranges are the fog lights or dim red lights not related to the brake pedal
  #33
Reddevil's Avatar
Fuse check
Relay swap
3rd high mount brake light works. Replaced fuse already, no luck. Here is a pic of my fuse box. I swapped the stop light relay with one of the other ones, no luck.
  #34
Old 11-23-2021 | 10:26 AM
Reddevil's Avatar
This is the light Im talking about:
  #35
Old 11-23-2021 | 10:34 AM
Reddevil's Avatar
Aint that a pisser! I didnt realize that was controlled by the other fog light switch! I feel stupid....nevermind then. Geez. Hkwever, the "check rear lights" stays on. I do have 2 bulbs out in the high center mount. Would that cause that display message?
  #36
Old 11-23-2021 | 10:50 AM
Parker 7's Avatar
Wifi going in and out
I have a summation of your findings
Reddevil (11-23-2021)
  #37
Old 11-23-2021 | 11:05 AM
Parker 7's Avatar
Since you have the high center brake lights you proved you have a good brake pedal switch , fuse # 8 , ignition switch ground path , and stop lamp relay closing
Your physical rear light assembly is different then mine as I have the X300 earlier version
  #38
Old 11-23-2021 | 11:07 AM
Parker 7's Avatar
The current sensor is a clue and can be tricky to decipher the information it gives you
  #39
Old 11-23-2021 | 11:11 AM
Parker 7's Avatar
Gotta get a Covid test lined up for a cancer surgeon Dr appointment tomorrow
So far non cancer in testing
  #40
Old 11-23-2021 | 11:17 AM
Parker 7's Avatar
The outside of my tail light assembly looks the same but there was some changes in the bulb layout and wiring for the X308
Quick Reply: No tail lights
