No tail lights
#41
i threw mine in the trash a long time ago
Reddevil (11-23-2021)
#42
So by removing 2 of your bulbs of the 5 the total resistance should decrease increasing your current flow to keep the inop tail light message out
The inop message light should come on with lowered current flow . an example would be a burnt out light bulb filament
Just put in the number 5 ohms for each bulb as an exercise you would have 3 over 5 vs, 5 over 5
#43
All of the lights work...now. I did not replace the 2 burned out bulbs in the high mount yet. I cant get the cover off. Feels like its gonna fall apart. There is a crack in the black housing that attaches to the window. I do have the trunk light bulbs out, they are burnt. Will that cause the message?
Parker 7 (11-23-2021)
#48
Maybe a pic of your broken high tail light assembly and maybe someone can identify the solution as the X300 may be different
Your light assembly repair would be a separate topic thread to start
I had the X300 off and can identify the difference if so
There was a good picture filled repair procedure for the X300 From Al R. that I saw before and can find later
coastaljag98
10-15-2012 10:19 PM
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
