No Timing Mark
The following 2 users liked this post by Sean B:
nurquhar (10-26-2012),
TN8Shooter (09-03-2012)
In the blackonxy timing chain procedure (I got it from the reference section on this forum) there is a diagram, I think pulled from JTIS, which shows a triangular timing mark. I too was confussed by this and rotated the engine several times looging for it thinking I had missed it.
Thankfully I found this thread and Sean's picture showing the single "rounded" timing slot.
One additional question though. Should the locking pin be tight in the slot ? My tool from the Laser 5147 kit seems less than tight once its in the CPS hole. I reckon I could rotate the flywheel a couple of millimeters either way with it locked. Is this good enough ?
The laser tool is a round peg with three flats machined on the end peg that engages with the slot.
Wolfy
05-28-2024 08:06 AM
Bhoyceltic
US Southwest
09-03-2015 09:11 AM
