No volts!
![Unhappy](https://www.jaguarforums.com/forum/images/icons/icon9.gif)
My 1999 XJ8 would lose all power to the dash,lights,starter everything. When I manualy open the boot,and check the battiery connections,the power comes on ! I have checked the connections for signs of trouble,but cannot find any,fuses,lose connections,grounds.Oddly enought,one time there was power at the 200amp fuses and the connections after but not at the engine compartment terminal
![Icon Werd](https://www.jaguarforums.com/forum/images/smilies/icon_werd.gif)
Dave Jag 1999 (08-12-2012)
I had a similar problem. No power. Open the boot and wiggle the ground strap and power comes back. For a while I carried a 10mm wrench in the cubby. I replaced the graound strap with an old-fashioned solid cable and cleaned up all the ground points. No problem since. But, I also had the boot hinge wire break problem. That is another story.
NTL1991
XJ40 ( XJ81 )
09-20-2015 06:22 PM
