non-return valve (bypass) - where to buy?
Greetings all,
It has been sometime I have been on the forum. Busy with work, moving to new house... all that good stuff. Time to re-focus on Her Majesty. I have had coolant leaks. Two so far fixed (one was a at a hose connector near thermostat, the other was the thermostat cap). I thought I was done, but no. Started losing again. Had a look today and bingo - appears to be the non-return valve (bypass, the one directly under the EGR, not the one near auxiliary heater pump) that is leaking from what appears a crack in the body of the valve itself. OK, so my hunt to find a replacement valve returned nothing besides purchasing an entire hose maze for $200. Com'on - no way to buy just the valve? Any clue anyone?
Thanks again MoscowLeaper. That has crossed my mind and good to hear that it's a reliable possibility. I found a used bypass valve (the one closer to the auxiliary water pump) which I am hoping (from what I could find in my research) to be the same as the one leaking (the one under the EGR). I will try to replace soon and report.
