Not Sure How To Resolve O2 Sensor DTC
I have an '01 XJR with a recurring CEL and DTC P1647 - Linear O2 Sensor Control Chip. From reading earlier posts I checked the silver pin leads on both sensors and both showed no resistance. I tested the plug leads back to the ECU and heater relays and everything is fine (no resistance). Before ordering a new sensor I decided to move the sensors to the opposite side to confirm I had a bad one and voila - the DTC disappeared. A week later the CEL and DTC 1647 have returned - this despite the sensor swap. This suggests the problem isn't with the sensors, but beyond the simple resistance check I'm not sure where to go now. All plugs/pins look pristine. Any thoughts will be appreciated.
Received 1,813 Likes
Well, I got out the shovel and dug up this old thread, let us know if it helps... https://www.jaguarforums.com/forum/x...nectors-55249/
I'm traveling, so I apologize for not getting back sooner. Here's my O2 sensor (up & down stream) replacement... https://www.jaguarforums.com/forum/x...cement-195018/
fineshines
11-02-2016 04:22 PM
Dayzel108
07-31-2014 12:11 AM
