O2 sensor and Cylinder Misfire
Hi, all.
Just posting to get an alternative viewpoint on this.
I’ve got the error codes:
P0420 - Efficiency Below Threshold
P0301-8 - Cylinder Misfire.
My plan is to replace to o2 sensor (if I can, am yet to research) and if the issue is still there then I’ll replace the ignition coils.
Only recently both codes came up.
My thinking is to replace the sensor as it's the cheaper fix, and if that does not fix the problem then change the coils?
Magdy Tawfik
02-13-2021 02:23 AM
lmerritt
03-04-2014 02:37 AM
