O2 Sensor Replacement
Old 10-21-2022, 06:03 AM
RandyS's Avatar
Yes, I have had the wrong part in the right box....several times. The hardest part of that is
convincing the salesclerk that you are not the one responsible for the switch. Especially so
if the part had to be shipped in and they have nothing to compare it with.
  #42
Old 10-21-2022, 06:33 AM
Addicted2boost's Avatar
Received 1,089 Likes on 839 Posts
Originally Posted by Highhorse
Dang, up early aren't we boys......+1 on Addicted's analogy.
I’ve been up since 1:30am. 🤦
Yesterday I woke up at 10:20am. 🤷‍♂️
  #43
Old 10-21-2022, 09:35 AM
Received 13,089 Likes on 6,521 Posts
Hi omsok,
Welcome to the Jaguar Forums! It's great to have you with us!
Addicted2boost nailed it: Here's a photo from Rock Auto showing the Bosch 15627:
Here's a photo of Denso 2349016:
For future reference, the Engine Management System in your car was made by Denso, as were, as far as I can recall, all of the critical EMS sensors. I highly recommend using Denso replacements whenever they are available, even though they may cost a bit more. The specifications of aftermarket sensors, even from excellent companies such as Bosch, may be close but not exactly the same as the OE Denso sensors, so better to be safe than sorry. If Denso parts are no longer available or affordable, then certainly parts from other OEMs such as Bosch, NTK, Delphi, Hitachi, etc. may be the best we can get.
Please visit the New Member Area - Intro a MUST and post a required introduction so we can learn something about you and your Jaguar and give you a proper welcome.
Cheers,
Don
The following 2 users liked this post by Don B:
AD2014 (10-21-2022), XJRay (10-21-2022)
  #44
Old 06-14-2024, 06:02 PM
XJRfatcat's Avatar
Hi all- I have the P1647 code, but the car is running as strong as it ever has. Is there a reason to replace this other than just getting rid of the Check Engine Light? If so, I'll pay my shop to do it, but not super excited about the bill for what looks like 6 hours of labor to change a silly O2 sensor that isn't impacting how the car drives.
Thanks.
  #45
Old 06-15-2024, 07:34 AM
Highhorse's Avatar
Received 1,797 Likes on 1,319 Posts
This is a fishing type code on the upstream driver side O2...that being to check the harness of the sensor for any damage. To root out the easiest and most common issue (the O2 itself), ..disconnect and check the harness (pins and wires, corrosion)...then meter the two same colored wires (usually black or white depending on maker) to the O2....these are for the heating element. All your doing is checking for continuity on those wires, you want zero for a closed loop if its good. If you come back with a reading, then it's open and that is almost 100% your issue, change the O2. If this isn't the issue, then it's fishing time, it may be a PCM.
If you look at Post #1, this is your culprit and procedure for replacement with as detailed an explanation as you'll find. This is very doable by a DYI'er, the part # is even on the box. Why they are charging so much time is a bit suspicious, it should only be about an hour, unless they think they have to do the other bank (Post #2), then that one is more time consuming, though I still don't think 6 hrs worth. Ask them if they are doing both upstream, that would probably explain the time.
  #46
Old 06-15-2024, 03:51 PM
RandyS's Avatar
Do an Ebay search for:
02-08 Jaguar X-Type X400 Exhaust Oxygen Lambda Wire Sensor Unit OEM upstream
and you will find many inexpensive O2 sensors that will work just fine.
Make sure it has 4 four wires or it is not the right part for the upstream.
Project8
XE ( X760 )
11-13-2021 06:51 AM
anjum
12-06-2016 11:40 AM
RaceDiagnostics
08-23-2015 04:48 PM
Wes_R
Detailing / Car care
09-06-2013 05:54 PM
Quick Reply: O2 Sensor Replacement
