O2 sensors...recommendations?
What year is your car?
I recently wrote a thread on this very topic the other day, about replacing X308 upstream O2 sensors with X-Type upstream sensors. You should be able to find it easily on here as it's very recent.
The early X308's had a 2-sensor system & around the 1999 model year they went over to a 4-sensor system.
I have a 2001 XJR with the 4-sensor system & one of the upstream sensors failed, giving fault code P1647-which on UK vehicles is the passenger side & on US vehicles is the driver side.
Code P1646 is for the sensor on the other bank.
The proper X308 sensor was very expensive brand-new from Jaguar, so I did some research & ended up fitting a cheap used upstream sensor from an X-Type, which worked fine.
Anyway, what year is your car? Can't go any further without that info
These codes definately point towards the front O2 sensor on bank 2.
Bank 2 is the LH side of the engine as viewed from the interior looking forwards, so that's the driver's side on US cars & passenger side on UK cars.
Pain in the *** to reach as the coolant expansion reservoir needs to be removed to allow access.
What's the VIN number of your car?
X308's up to VIN number 853935 used front O2 sensor part number: LJA1680AE
VIN's from 853936 to F06182 used part number: LNE1684BA
VIN's from F06183 used part number: LNE1684BB
