OBD 2 questions
Old 12-27-2023, 06:37 PM
ForTheLoveOfCars's Avatar
Default OBD 2 questions
Okay everyone i thank you all for your help in my previous endeavors on this beautiful Jag i am struggling to understand why my $500 obd2 reader refuses to auto connect key in second position as it should be and yet i cannot get it to auto connect ive tried while driving ive tried parked ive had the battery out and back in more times then i can count im getting flustered with it i had a similar issue with my 02 X-type and a cheap OBD 2 reader and when o reillys still supplied a real scan tool to troubleshoot issues now you have to bring it into them like autozone anyways i CAN however get the codes i CANNOT erase them i only get a request to do so it will read them no issue but thats it live data says its not supported on my vehicle while i drive now as to how complete this is im not sure but it is at least accurate as for which codes were being flagged now i had it in the dealership in town (NOT a jag dealer but a honda dealership) they WERE able to clear the codes why can i not??? Do i have to buy a snapon solus or something? Ill scratch my head in confusion while i eagerly await this response as im totally perplexed at this my scan tool is in working order and it is updated enough to respond flawlessly to the 2002 x-type as suggested my tool is an innova 3170RS using it on a 2001 XJR x308
Old 12-28-2023, 05:38 AM
JagV8's Avatar
Received 4,535 Likes on 3,944 Posts
Someone may have ideas if you post car details & tool details otherwise people will be guessing.
The following 3 users liked this post by JagV8:
ForTheLoveOfCars (12-28-2023), Jtestrake (12-28-2023), motorcarman (12-28-2023)
Old 12-28-2023, 08:59 AM
cityboy's Avatar
I use the inexpensive ELM327 reader and connect through my iphone app. It works flawlessly, I have to clear codes on this POS almost every day! Grrrrrrr.....
Old 12-28-2023, 02:23 PM
understood ive corrected my post its an innova 3170RS and a XJR 2001 X308 i just feel its not the tool the tool works great on the other car i tried that too and went back to my XJR again no cigar the shop clearly had minimal if any issue clearing the codes i do have a pending a vacuum leak code P0442 could that be why it wont clear? Maybe the code is active but even then on my x type i could clear the codes
Old 12-28-2023, 02:24 PM
ive heard great things about the elm fortunately its not the tool (:
Old 01-03-2024, 02:18 PM
JagV8's Avatar
Sorry I don't know enough about the workings of both car & that OBD tool but some tools don't cope well if a car has a valid but unusual address for a module.
ForTheLoveOfCars (01-04-2024)
Old 01-03-2024, 03:42 PM
RJ237's Avatar
Received 2,812 Likes on 2,242 Posts
Check that the reader is using protocol ISO 9141-2.
Old 01-04-2024, 05:20 AM
How do i do that? And thank you
Old 01-04-2024, 10:38 AM
RJ237's Avatar
It should be in the setup section of your device, or call them.
ForTheLoveOfCars (01-07-2024)
Old 01-04-2024, 03:21 PM
hispeed42's Avatar
I have an Innova 3160b and it works fine on my car. The problem is more than likely what RJ said and the scanner should recognize the ISO at startup. If not, go to settigs.
Old 01-04-2024, 07:22 PM
M. Stojanovic's Avatar
Old 01-07-2024, 04:00 PM
ive been through this code reader many times I’ve actually never seen a setup section as you suggested is it possible to tell via the startup page shows it running
Firmware: V 18.02.02 (2018)
Boot loader: V 18.00.01
Database: V 18.03.06
copyright 2019
is it possible doing a full blown reset on my code reader will allow it to utilize the protocol you mentioned? i can run out and check the car too see if it pulls up that protocol while connected also but as its winter and very cold itll suck lol and this brings another question to mind why would it work flawlessly on my x type? Does that car not utilize the same coded protocols?
Old 01-07-2024, 04:01 PM
Originally Posted by M. Stojanovic
what am i looking for on here? I do see the specifics but didnt see it mention using a protocol as mentioned by RJ
Old 01-07-2024, 04:03 PM
what am i looking for in the settings hispeed? Thank you 🙏
Old 01-07-2024, 07:39 PM
RJ237's Avatar
Since I never had an Innova I don't know what to say. Maybe the X type works because it's more Ford? I do know that one of my devices works fine on my jag and Maserati but not my Fiesta.
Old 01-07-2024, 11:31 PM
thats a good point so in that case which code reader works for you? Im tempted to find a decent used snapon at this point
Old 01-08-2024, 12:55 AM
https://www.innova.com/products/fixa...erage-template
I can see that, when the Jag model etc. is keyed-in, it shows what Innova 3170RS can do for that model. I thought that that would be sufficient info for your determination whether the scanner should work on your car.
ForTheLoveOfCars (01-09-2024)
Old 01-08-2024, 04:24 PM
hispeed42's Avatar
My Innova is in the car, and the car is covered with snow, so it's not accessible right now. On mine, the initial startup has a menu of supported car brands and I'm assuming this is where it gets the ISO to use. I just scroll down to Jaguar and it hooks up. I get the DTCs that are supported and can clear them, and Live Data. I would have to go plug mine it to see if there's a "settings" selection along with the brand selection.
I also have an Autel MX808 that has more features and scans all of the car's modules, so I get codes from everywhere. I highly recommend this unit, but it is a little pricey.
Old 01-09-2024, 07:07 AM
funny you mention the MX808 as im actually bidding on one from ebay right now lol
Old 01-09-2024, 09:43 AM
RandyS's Avatar
Different tools for different folks, I guess. I have found that sometimes it's not what is displayed on the reader,
but the way it is displayed on the reader that helps various diagnostic processes.
The following 2 users liked this post by RandyS:
ForTheLoveOfCars (01-17-2024), hispeed42 (01-09-2024)
Quick Reply: OBD 2 questions
