OBD can't see fault codes even when connected
Today I found out that my OBDII to USB module doesn't retrieve information about fault codes from the car's ECU. I tried with several software - all of them are able to connect the car, to preview live data from different sensors, but always shows up that there is no active or stored fault codes... The problem is that I accidentally switched on Drive while the car was lifted and the ABS and ASC faults appeared on the dashboard... and now I'm unable to clean them.
My OBDII reader is ELM 327 ver. 1.6. and it looks like this one:
![](http://cdn103.iofferphoto.com/img3/item/511/321/432/l_elm327-usb-obdii-obd2-can-bus-auto-car-diagnostic-scann-3ed9.jpg)
Estilian (09-15-2012)
trosty
26
12-18-2022 06:40 PM
OkieTim
09-08-2015 04:48 PM
