OBD-II Port Malfunction
omgimali (10-25-2016)
omgimali (10-26-2016)
Correct on the location.
There were quite some readers in the past not working, but I think most of that has settled.
Not sure if you use Bluetooth or a fixed one, but if you use a bluetooth version, you should see the Bluetooth unit trying to connect to your phone.
There is also a LED on the Bluetooth unit, confirming power on the plug.
Although nothing is impossible, I can hardly see how the plug should stop working, and I don't think there is a separate fuse for it, but that is easy to check.
EDIT: I read in an other thread that an I-phone and Android phones need different Bluetooth devices.
Again, not sure what you are using ...
