OBD port issue
Hi to all
I am having a strange problem with the OBD portion connection. my mechanic was able to connect it with his scanner but when trying to do the NY state inspection. His computer would not reading my car. ( he was able to do the state inspection for the other cars thou)
I am having a strange problem with the OBD portion connection. my mechanic was able to connect it with his scanner but when trying to do the NY state inspection. His computer would not reading my car. ( he was able to do the state inspection for the other cars thou)[/QUOTE]
I have had my OBD scanner claim is was not connecting at times on my cars. Not sure what the problem is but generally disconnecting and reconnecting would make it work again. Perhaps try a different test station? BTW; do you have an OBD reader? Does it connect and if so, do you have any current OBD problem codes being reported?
Jhartz (07-04-2024)
Don B (07-04-2024)
Received 13,255 Likes
I have a very high-end Autel MaxiSys Elite scan tool that does not like to communicate with our 2003 XJ8, so instead I use my Launch Creader VIII, which may be 10 years old. I suspect there is a problem in the software in the Autel that causes it to not recognize the X308. Ask your mechanic if he has an older scan tool he can try on your car.
Cheers,
Don
Cheers,
Don
I have an Autel MX808 MaxiCheck and haven't had any problems connecting. Do you subscribe to the updates?
Yes, I re-subscribe the MaxiSys Elite about every 2 or 3 years when they have a 50% off sale, and about the same for my four or five other lesser Autel tools (MaxiCheck, etc.) During the 12-month periods when the tools have active subscriptions, I install all the relevant updates that are offered for vehicles I work on.
![Icon Beerchug](https://www.jaguarforums.com/forum/images/smilies/icon_beerchug.gif)
I did, and they do. But, those emails go to the "Promotions" box in gmail, and I usually only go there to clean it out. I'll have to fix that so the emails show up in the inbox.
