OBDLink SX
This reader was recommended several times in this forum for retrieving codes regarding air suspension faults. I plugged her in & seems to work fine as far as the downloading of the drivers and software, etc. Cord plugged into the car and the laptop nicely.
Received only one code P...; I'm looking for the codes beginning with C of which there should be a few. I also replaced an AC sensor that was defective last month; would've thought that there would have been a stored code from the failure but there wasn't. I'm hopeful that someone reading has used this machine & might be able to tell me what I need to do to get this to work properly.
There is one part of the program where you can get rpm, fuel consumption and other variables. When I turned this feature on, all of the instruments on the computer screen were reading zero as though they were not connected to the car.
04Xjrsteve (10-27-2013)
