ODD sounds and sort 2001 Jaguar xj8 VDP
Morning guys! Just went out to start the XJ8 VDP.. engine didnt kick over completely....so I went to restart it. Now when I turn the key it simply makes a loud sound and doesnt even remotley kickover? Any ideas what this might be???Where I should begin my troubleshooting?
NOTE* the loud sound sounds like if you were to have the car running and try to start it while running..that loud sound that action makes...Thanks mates!
The starter motor gear could be failing to engage the flex plate gear and just grinding against it. Perhaps a symptom of low voltage at the starter. I would certainly measure that before pulling the starter. Should have at least 10.5v at starter B+ under load. Less, battery/wiring. More, starter.
Remove the cover on the RH firewall extension and you will see a cable with a rubber cover. That is the B+ power from the battery. Connect a volt meter there to ground and try a short start to see what happens to the voltage. It should not drop below 10.5v. Beyond that you are going to have to test this from below the car. DO NOT get under the car on the Jaguar supplied jack.
BrentGardner
28
04-26-2024 03:08 AM
philwarner
12-06-2021 07:13 AM
FS[MidWest]: FS: 1999 VDP *lots of pics* in mid-Missouri
souldoubt
08-25-2015 08:15 PM
