Odometer correction adjustment (IDS?)
You need the engineering mode enabled in order to run the odometer correction routine, but i've tried it on a couple of cars and it hasn't worked.
I'm lead to believe that the odometer data is stored on a separate chip in the instrument cluster, and you can simply swap that chip over from your old cluster to the new replacement.
