Ohm readings on ABS Module
Received 13,425 Likes
Hi Joeizme,
I have moved your post from the X350 forum to the forum for the X308, which is the Jaguar factory code for your 2001 VDP. In this forum you'll have a better chance of receiving replies from owners of similar cars.
You may also have a greater chance of helpful replies if you share the symptoms that have prompted you to measure the resistances at the ABS module since this may open up other avenues for diagnosis.
Also, I notice that although you've been a member since 2012, you've never posted an introduction. Please visit the New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum and post an intro so we can give you a proper welcome and also learn something about you and your Jag.
Cheers,
Don
Cheers,
Don
Joeizme (10-16-2014)
trosty
26
12-18-2022 06:40 PM
