Oil in Air Intake
Old 07-26-2017, 08:17 PM
jcvegasdog's Avatar
Default Housing from throttle body to maf
98 xj8: Removed housing, oil coming from breather hose on valve cover. Inside housing found oil up to throttle body. IS THIS NORMAL? Any filter on the breather hose?
Old 07-27-2017, 12:58 AM
jcvegasdog's Avatar
Default Oil in Air Intake
98 XJ8: Cleaning throttle body & maf, found oil in housing between them, is this normal? Hose from valve cover to housing, is a filter used in hose? Also cleaned oil in housing, was this a mistake?
Old 07-27-2017, 06:30 AM
Daim's Avatar
Received 2,181 Likes on 1,584 Posts
Totally normal. It is the crank case ventilation system and the oil condenses there...
jcvegasdog (07-27-2017)
Old 07-27-2017, 07:52 AM
xjr2014_de's Avatar
+1 on what Daim sais.
As long as you don't have oil puddles in the intake system, you're fine.
If you're concerned then clean the intake + TB, drive a few weeks and if you have puddles again, then there's sth wrong.
But an oily layer in the intake is quite normal.
Old 07-27-2017, 10:04 AM
Received 8,138 Likes on 4,910 Posts
Here it is again!!
bob
The following 2 users liked this post by motorcarman:
jcvegasdog (07-27-2017), Jhartz (07-27-2017)
Old 07-27-2017, 08:18 PM
omgimali's Avatar
If I clean this engine breather will it "restore" lost power.
