Oil change
Old 02-15-2016, 03:13 PM
plums's Avatar
Received 2,181 Likes on 1,621 Posts
Originally Posted by yeldogt
This is the OE filter.
You can see it has a proper rubber bypass with a proper spring w/ support.
It's a hefty filter.
BTW, the manufacturer should be Crosland in the UK.
Old 02-15-2016, 04:33 PM
sparkenzap's Avatar
Received 1,064 Likes on 867 Posts
I am pretty sure robots are not installing coolant lines on engines! And which new cars is it that have rubber bypass lines?
Old 02-15-2016, 05:30 PM
yeldogt's Avatar
I believe this was mentioned --- I know my buddy has ordered what is the cross-reference.. It's different.
That's not saying it's not =or good enough.
Old 02-15-2016, 05:32 PM
yeldogt's Avatar
The engines are fully fitted prior to being married to the car. The quick connections allow the engine to be "quick" connected to the body
Old 02-15-2016, 06:17 PM
plums's Avatar
Which is also why the two famous leakers are under the intake.
It makes for a more easily handled package during assembly.
Not so easy when they fail though.
Panthera93
01-26-2016 11:48 AM
Hotbaz
01-26-2016 08:46 AM
dcab1017
01-24-2016 07:43 PM
Rajamogan
01-19-2016 11:00 AM
Quick Reply: Oil change
