Oil Change
The dealers use regular oil when they perform an oil change. You are fine using regular oil -- use the proper weight per owners manual. I switched to synthetics when I stopped driving the car as often -- synthetics are good for two years, regular oil should be changed at one year.
Don't play with the transmission until you do some research.
aholbro1
08-05-2021 05:02 AM
