Oil Consumption
Greetings Everyone:
Very much in love with my used 2002 Jag VDP (non Nikasil) with 82,000 miles. Promise I will post a pic soon. The car is just a stunner. After driving for a month, have noticed something...the car seems to be burning oil at a rate I'm not used to...about a quart every 1,500 miles, this in the face of the following:
1) Checked out by a great Jag specialist for compression, as part of his assessment of the car, who also replaced leaky valve cover gaskets, and there are no other leaks of any kind
2) Passed California emissions with flying colors...super clean on emissions
3) Runs smooth as silk, silent idle
4) Oil not soiling between changes...very clean
5) Car is averaging 20 to 21 MPG in mixed driving (I'm a gentle driver) and that includes using A/C
...are there seals that are internal that need replacing (valve stem?)...I havent brought it up to my mechanic...figured I would at the next service. Should I be worried? The engine doesn't sound or feel tired...thanks for your input.
Assuming that you have not changed the oil yet, it may be that there was a lot of blow-by in the oil,, maybe due to a lot of short runs before you bought the car, and that is now evaporating, lowering the oil level. I would give it another one or two thousand miles, checking the oil regularly, to see what happens. If oil usage is high, try heavier oil, as previous poster suggested.
In the words of Douglas Adams and corporal Jones (dads army)
Don't Panic
Even if it does continue to use oil, the car has been checked out and runs nicely, so you are not likely to have a catastrophic failure, just factor it in to the running costs.
Don't Panic
3jagfamily
10-01-2015 01:49 AM
FS[MidAtlantic]: 1997 XJ6 VDP $3,900 - Very RARE Anthracite on Warm Charcoal
42Ajd
09-26-2015 07:04 PM
Woznaldo
09-26-2015 11:02 AM
