Oil dipstick removal
![Unhappy](https://www.jaguarforums.com/forum/images/icons/icon9.gif)
Hi Guys
Finally managed to get the correct gaskets for the cam covers on my 2000 XJR and have set about checking the secondary tensioners.
Got the cam cover off the right hand bank with no major issues and fount that the car has the 1st gen tensioners. Got the replacement tensioners and bolts along with the locking tools so good to go.
Problem is I cannot remove the left hand cam cover as the oil dipstick tube will not move. I did think of cutting the tab that holds it to the cam cover with my dremel but I am struggling to get the dremel in due to numerous pipes etc in the way.
Is there any method of removing the tube apart from brute force ? If I can get it to lift about an inch it should clear the stud it attaches to and allow access to the cam cover bolt underneath.
The following 2 users liked this post by RJ237:
Dan R (12-06-2014),
motorcarman (12-06-2014)
I use a 'hook-tool' and a small slide hammer to dislodge the tube.
LEAVE THE DIPSTICK IN THE HOLE. It is longer than the tube and will guide the tube back into the hole when you are done.
If it is your car, you can do whatever way you want, but cutting/damaging other peoples car parts seems to PI$$ them OFF.
I pull the tube but cutting the tab will work if the tube is STUCK!!!
bob gauff
bob gauff
markdpeter (12-30-2023)
aholbro1
08-05-2021 05:02 AM
