Oil Pressure and Temp Sending Unit Replacement
So I've tracked down every other oil leak and fixed them and the only place I can find that's leaking now is this pair of sensors/sending units located by my oil filter.
Two things.. What are the part numbers for each? Are they replaceable with the engine full of oil? I found this after I had drained the oil pan during an oil change and had no way to go get the parts without replacing the filter and filling the engine again with new oil. I'd rather not wait until my next oil change to do this.
Eric
Here are the two units in question:
Eric
![Name: image.jpg1_25.jpg
Size: 206.7 KB](https://www.jaguarforums.com/forum/attachments/xj-xj8-xjr-x308-27/154997d1501210486-oil-pressure-temp-sending-unit-replacement-image.jpg1_25.jpg)
BrentGardner
28
04-26-2024 03:08 AM
Tony K
03-26-2024 01:53 PM
