Oil Sender/switch which one to buy
Hi all
firstly my Jag fire first turn over just using the key only about 3 sec and she starts
anyway I an buying bit here and there, MAF sensor hoses senders, serpentine belt ect just to replace as all I am sure are old, and as I go for 800klm drives don't want a breakdown.
so the oil sender I purchased is AJ8 4853 this is a 60psi sender/switch XJ8 X1998-2003 XJR 1997-2003
other part numbers are C31177 60psi & C15474 100psi sender/switches I think are for E-Type and V12 engines
so the question is which one?
Don B (07-20-2019)
GvilleVDP
05-29-2013 10:10 AM
