Oil on spark plug treads
Received 12,952 Likes
Cheers,
Don
firenfix (03-15-2014)
Thanks guys, pulled the other 6 and the oil is in the plug wells. Seems as I pulled them out they were passing through the standing oil causing the appearance of oil on the threads. Putting in new plugs for now and ordered a new gasket set with the o-rings
Thanks again!
Thanks again!
Engine oil seepage from the cam cover spark plug well seals.
When cleaning up the whole area,use carb cleaner and spray down into plug well....with plugs out and either blow dry with air or, wipe excess out with cloth on a wooden dowel.
When replacing plugs, add a dap of nickel anti-seize on the lower half of the plug threads for 180 deg. with a small paint brush and torque to 20lbs/ft.
You are going to replace cam cover seals anyway so, make sure mounting surfaces are clean and dry.
Spray carb cleaner on mounting surfaces....DO NOT use any sealant!
These are a 'compression' type seals....making sue they sit properly in the grooves in the cam covers.
you can hold them in place with a small dab of pet. jelly.
The only place a small dap of sealnt is used is over the joint between front of cylinder head and timing cover...a bead about 3mmx12mm is all.
Don't overtighten the cam cover screws!....8nm.
Work in criss-cross patern starting from centre screws.
While you have cam covers off, it pays to check and clean the breather
baffles in both covers...these are often over looked.
