Oil weep from LH cam cover
Oil is weeping from where the small bore breather tube post exits the LH cam cover. It look like the cream sealant is breaking down and allowing oil mist to escape.
Any tips on sealing it up?
I was thinking of cleaning with brake cleaner and then trying to get some sort of sealant down the crack.
Thanks,
Dan
Thanks,
Dan
that should work. the valve cover is $300 and its a factory only part. But after I spent $1700 on other leaks I bought it and as Edd China says JOB DONE!
Dan R (08-14-2014)
aholbro1
08-05-2021 05:02 AM
